There are several Job Processors. Periodically on any problems may arise. Is it possible to view the properties of Vault, the "name of the machine" that was launched Job Processor, created specifically for the DWF?
When you enable the hidden files and take a look at the system properties of any DWF there are tow interesting for your query. They are "Created By" where the User name is populated which Job Processor was logged with, and "Current Owner" which is populated with "MachineName\AUTODESKVAULT" which indicates the machine name where Job Processor was creating this DWF.
Hope it helps.
There are several JP, login Administrator account:
PC1
PC2
To see where you created the DWF, on each machine I scan «C:\Program Files\Autodesk\Vault Professional 2014\Explorer» JobProcessor.log.
Bad that there is no property "by machine": PC1 ...
When pointing you to the property "Current Owner" I did not mean any information in the JobProcessor.log but I meant directly the file property in the Vault Explorer when you enable the hidden files and take a look at the system properties of the DWF file. And - provided the hidden files are enabled - you can search for these files.
Hope it helps
