Vault General
Active Member
tnafbrat
Message 1 of 5 (916 Views)
Vautl Server 2012 Installation Failure
916 Views, 4 Replies
10-18-2011 01:00 PM
I had Vault Server 2012 installed and working this weekend.  When I attempted to open and login to the server console today I received the following:
Failed connecting to SQL server - 'server=localhost\AUTODESKVAULT;userid=sa;password=*****;'
I have not changed any passwords?  I tried uninstalling however when I attempted to re-install, it will not install, it gives the same message.  What the heck did I do?
Product Support
herrerh
Message 2 of 5 (910 Views)
Re: Vautl Server 2012 Installation Failure
10-18-2011 01:46 PM in reply to: tnafbrat
In Control Panel -> Administrative Tools -> Services, can you see if the SQL Server (AutodeskVault) service is running still?
If not, will it start?
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Active Member
tnafbrat
Message 3 of 5 (899 Views)
10-19-2011 05:30 AM in reply to: herrerh
Thank!,  SQL Server services were all disabled.  I changed those to automatic.  I was able to start the "SQL Server Browser" and the "SQL Server VSS Writer"
.   The "SQL Server (AUTODESKVAULT)" <ERROR 2:  could not find the file specified> and the "SQL Server Agent (AUTODESKVAULT)" <ERROR: 1068: The dependency service or group failed to start> and the "SQL Active Directory Helper Service" <Windows could not start the SADHS on local computer>  would not start.
   Since the Vault server has been uninstalled, I am now going to attempt to reinstall to see if that will clear the rest of the problems?
Active Member
tnafbrat
Message 4 of 5 (895 Views)
10-19-2011 05:48 AM in reply to: tnafbrat
Update - Attempted to run the install and still received the following message
Active Member
tnafbrat
Message 5 of 5 (891 Views)
10-19-2011 06:36 AM in reply to: tnafbrat
I opened the SQL Server Config tools and noted that the 2 AUTODESKVAULT options were "Stopped".  I "started" them, rebooted and began the ADMS installation again.  It is now installing.  Progress made so far.  YAY!
Thanks so much.  Your question about the SQL service started me on the hunt.  I had no clue where to begin being a "user" and not an IT person.
Denise
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
