Good morning,
We are running Autodesk Vault Basic 2013 with two Vaults.
One Called Products and the other called Vault.
Product – Should be only ready for Group name Product (read only)
With the follow setting
Roles: Document Consumer
Vaults: Products
Groups:
Group Members:
-User 1
-User 2
-User 3
Vault – Should be ready and modify for Group name Vault
Roles: Document Editor (level 1)
Vaults: Vault
Groups:
Group Members:
-User 1
-User 2
-User 3
The problem is everyone has permission for modify and edit in vault called Products.
Some can help me.
thank
My first question to you is, why do you have multiple Vaults?
Good morning and thank for posting your issue. Roles and security are not Vault specific. However, if you upgrade to any of the other three Vault products (Vault Workgroup, Vault Collaboration, or Vault Professional), you would have several more options for controlling the security of your data.
Folder security allows you to specify what level of access each user/group has on a folder structure. In addition, lifecycles can be used to drive the security based on lifecycle states of the files and folders.
Adam
We has standard part in the company, we only make change to those part with engineer changes, not one should be touch or chance those part without permission.
The other one is for costumer job, every have access to work there.
A better route would be to upgrade your Vault from basic, so you can utilize folder level permissions and document workflows. With basic Vault, you're very limited.
Creating multiple Vaults for this purpose will make it difficult to share files.
