Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault shortcut not working
3 REPLIES 3
jacoj
356 Views, 3 Replies
can Any one assist,
two of our users Vault shortcuts is not working,
when you rightclick on any file/folder in the vualt explorer, and select create shortcut, the shortcut gets created,
but when you try to use the shortcut, vault stated fiels have been changed/moved and then directly remove the shortcut.
on other machine this works perfectly.
any idae why this occurs.
I did check the html shortcut file in the app data setting and it seens fine ( not hidden, not read only )
help please
3 REPLIES 3
Senthil_Kumar
in reply to: jacoj
Ensure the client is refreshed to show the latest file content before creating the shortcuts. What happens if you create a new shortcut and then if you access the shortcut immediately after creating the shortcuts?
It will be also good if you can post a video showing your workflow.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
jacoj
in reply to: jacoj
thank you for the reply, this is the issue, If I create it, want to use it emedietely it gives that error, statiing firl has moved/ change.
the video show my machine, the screenshot the users machine? both dirrectly created and accessed
Senthil_Kumar
in reply to: jacoj
Sorry I see only the screenshot. Can you reattach the video OR send it to senthilDOTkumarATautodeskDOTcom?
Senthil Kumar
Autodesk, Inc.
