Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault server installation failing
3 REPLIES 3
tmccar
426 Views, 3 Replies
I have been trying to install Vault server and it is failing with the following message: "Install AMS Check. Failed Installation aborted, Result = 2"l .   What could be the reason for this message?
3 REPLIES 3
chearhuat
in reply to: tmccar
Hi tmccar,
During the ADMS pre-check prior to installation, we will list the causes, and possible solution to those errors.
Could you help to examine those?
Also, if you could, please send us the log file in %temp folder, that'll help us to do troubleshooting too...
thanks 🙂
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
tmccar
in reply to: chearhuat
Hi
  When running the System readiness checks, it is failing with the message "ASPX file failed to run at  "locahost/testASP/TestASPNet.aspx".
 If I try to open that link in a browser, I get the error message "
Handler "PageHandlerFactory-Integrated" has a bad module "ManagedPipelineHandler" in its module list"
tmccar
in reply to: tmccar
OK, it's now installing fine. I got  working by uninstalling IIS and also renaming the "c:\inetpubb\wwwroot" folder. I ran the 2012 Vault server installation and let it do the IIS installation, and create the "wwwroot" folder.
