I want to re-index a vault of about 176 gig, but it stops atre a few minutes with an error messsage about the timeout. Is there a fix for this? (I have Vault Pro 2012 with SQL Server 2008 R" express)
Solved by herrerh. Go to Solution.
You can change the timeout settings in the web.config file. More details on making the changes can be found in the Advanced Configuration.
Start y doubling the first value and double the other two if it still fails.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16853779&linkID=9261341
-Hywell
I have increased the figure to 1,200,000,000 and it is still timing out.
I notice you say "double the other two", but there are ony 2 variables mentioned in the config guide: "timeouts connection" and "executiontimeout".
In the timeouts sectino, there are three values, connection, defaultCommand and longcommand. Those are the three that should be changed.
Change them to 360, 720, 2600 as a start.
Change your maxRequestLength back to the default of 51200.
After changing the variables, do an IISRESET.
-Hywell
