When I search for a file it shows the correct versions in the view panel on the bottom, but as soon as I check out the parent file, the attachments change to an older version ?
See my attached picture. I see version 4 but after checkout of the parent, I get version 1 of the attachment ??
If I checkout from the top panel it seems to grab the correct versions..
I am using Vault 2011 and Inventor/AutoCad Mechanical 2011
So what I see is not always what I get ...? Help !
Hi there,
This does seem a little odd given some of the workflow you have shared and it may be best to create a support case to further investigate, but hopefully the following explanation is something you can test.
In Vault under the uses tab by default, we always shows "latest", this means we show the latest of every file, HOWEVER, the file when it was added might actually point to a different version (it was checked in with reference to version 1 and then at a later time someone added version 4 of the excel file which has not been updated in the drawing).
When you open from AutoCAD, Vault opens the LATEST of everything by default, meaning your drawing will now consume the latest version = 4.
In older versions of Vault though open from Vault Explorer defaults to open rev bias, so you would not necessarily get latest - it may get the version that was referenced.
Why I say this is odd in your case though is that this behavior should be consistent regardless of where you open in VE and you don't seem to be using document revisions or getting older versions.
HI there,
Sure, do you have a subscription / support contract in place or are you able to contact your software partner to log a case and start investigation?
