I realize the WSE 3.0 is not supported on Windows Server 2008, and that the Vault Integration requires the WSE 3.0 plug in
Is there plans to fix this issue, so that the server can run on 2008 and use possibly WCF instead of the obsolete WSE 3.0
We are dead in the water with this integration, client does not want to put an old server operating system on a new Sharepoint 2010 server.
thoughts?
Kim,
This does work with SharePoint 2010 and Windows Server 2008. You must be having some other problem. Have you logged a support ticket?
Although WSE is "old" technology, it works just fine on Windows 2008. Vault just uses it just a communication library. It won't affect SharePoint in any way.
