I have a problem .
How can I solve thıs problem
we need help
Try this:
In the IIS Manager, first click on "Application Pools" and make sure the default pool is set to .NET 4.0, Classic Mode. See attached "iis-0.png".
Then click on the toplevel node on the left (your machine hostname) and double-click on "ISAPI and CGI Restrictions". See attached "iis-1.png".
Make sure ASP.NET is set to "Allowed". See attached "iis-2.png".
DarrenP
rerun the install after doing this
DarrenP
Hi ,
I have tried with all the solutions you mentioned. Still i am getting the error. Could you please help me with some other solution.
Thanks.
did you go through this: https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
DarrenP
