Gav,
When you use the Open in the attach picture, it is opening files that is on
your local workspace not files from the Vault.
To correct this, close all open files in Inventor.
Select Map Folders from the File\Vault menu.
Map the project workspace folders to the appropriate folders in the Vault.
Then you should be able to perform a Open From Vault.
Irvin
wrote in message news:5310618@discussion.autodesk.com...
Hi, I am trying to get all designs created within Vault for drawing
managment purposes. When I open the from the Vault icon in Inventor I get
this error "The active project's workspace is not mapped to a path in the
Vault. In order to proceed the workspace must be mapped". When I just use
the "Open folder" icon it opens to within the Vault absolutely fine. My
project set up is pointing towards my Vault folder on my C drive see pic so
I am unsure as to what is wrong. I have tried the he
lp files to no avail. ANy ideas please.
Gav
