Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault for simple .Dwg file management with Civil3D
13 REPLIES 13
Message 1 of 14
jkwilliams
627 Views, 13 Replies
I have a number of licenses of Civil3D 2011, and I wish to use standard Vault for simple Check-In and Check-Out of .Dwg files, without all the references etc to Civil3D projects etc.
Is there a way I can configure Vault for simple .Dwg file management as it works with standard AutoCAD or AutoCAD Map?
Jim Williams
13 REPLIES 13
Message 2 of 14
Richard.Rankin
in reply to: jkwilliams
Can you tell me why you would need to do this?
What is it about the interface that makes you want to revert to the base AutoCAD functionality?
If you find my response solves your question, please click the "Accept Solution" below the response
Richard Rankin
Vault Support Specialist
Global Product Support
Autodesk, Inc.
Message 3 of 14
jkwilliams
Richard,
Thanks for your interest here.
As mentioned earlier I need simple Check-In and Check-Out of .Dwg files, without references to "Civil3D Projects".
The standard AutoCAD interface does not require the user to select a Project, and I would like my Civil3D users to use the same as my AutoCAD Users, for support and training purposes.
Jim
Message 4 of 14
Richard.Rankin
Hi jkwilliams,
I asked this question internally to see if we could offer any alternative suggestions. The bottom line is, if your users are using C3D features like Points, Point Groups, Intersections, they should be using the C3D Vault Addin Interface. The C3D Vault supports those features.
If the users are not using those C3D features, they can close C3D and run the Vanilla AutoCAD profile to get the standard AutoCAD Vault checkin interface.
I hope this helps.
Richard Rankin
Autodesk, Inc.
Message 5 of 14
jkwilliams
Richard,
Thanks for your comments here.
My users of Civil3D will be usign the software for Survey related work, preparing mainly Parcel deposited Plans, but will use Points groups, and some basic TIN surfaces, but will not need to share C3D objects.
I do however want thier data backed up in our Vault configured for AutoCA use with other internal departments.
Why would I use the Vautl for Civil3D, when all I need is simple Check-In and Check-Out?
Id I don't want to actual share C3D Objects, why would I use it?
Jim
Message 6 of 14
jkwilliams
Richard,
You wrote earlier:
I assume you mean use the AutoCAD "2D Drafting & Annotation" Workspace?
I have tried this, and I still get prompted to select a Civil3D Project, which is not what I want.
Any way around this "Project" issue with Civil3D?
Jim
Message 7 of 14
chearhuat
Hi jkwilliams,
In native ACAD, vault uses XREF ESW (Enhanced Secondary Window) for all the vault operation. Probably you could try it out...
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 8 of 14
jkwilliams
in reply to: chearhuat
Chear,
Thanks for the suggestion of using XREF ESW (Enhanced Secondary Window).
How would I access this within Civil3D 2011?
Jim
Message 9 of 14
chearhuat
Hi Jim,
You could invoke XREF ESW via commandline, 'XREF'. Do note that 'XREF' will have no information of C3D project, and all its contained file relationships.
Chear Huat.
Chear Huat
SQA Analyst
Autodesk, Inc.
Message 10 of 14
jkwilliams
Chear,
I have run the XREF command, and there is no clear way of doing a Check-In or Check-Out in Vault with no reference to a Civil3D Project.
If I select the file in the XREF Window, I am still prompted to select a Civil3D Project.
How do I work around this?
Message 11 of 14
Richard.Rankin
In response to you asking for clarification on what I meant exactly. I meant close AutoCAD Civil3D 2011, then from the start menu, go programs>Autodesk>AutoCAD Civil 3D 2011, but instead of clicking AutoCAD Civil 3D, click "AutoCAD 2011".
Sorry for any confusion. I hope this is clearer.
Richard Rankin
Autodesk, Inc.
Message 12 of 14
jkwilliams
Richard,
I have made it quite clear I feel:
I do NOT wish to have to deal with a Civil3D Project, as my Civil3D Drawings will not have any relationships between them.
That is why I wish to use the standard AutoCAD interface.
How can I do this?
Message 13 of 14
achintam
If you are using Vault 2011 with Civil 3D 2011, there is no way to turn off the project-based Check In wizard as it was designed to benefit object-based workflows in Civil 3D.
Message 14 of 14
jkwilliams
Thanks Richard,
I understand that this can be achived withthe standard AutoCAD profile, and this works, however it would mean closing down the Drawing in Civil3D and opening it up in AutoCAD to do the Check-In and create the .dwg visualisaton file.
It seems clear to me that it will be best to create a seperate C3D Vault Database based on a Civil3D Vault Project, and have all the Civil3D Survey users connect to this Database.
Best Regards,
Jim
