Vault General
Active Contributor
jkwilliams
Message 1 of 14 (196 Views)
Vault for simple .Dwg file management with Civil3D
196 Views, 13 Replies
10-04-2011 02:12 PM
I have a number of licenses of Civil3D 2011, and I wish to use standard Vault for simple Check-In and Check-Out of .Dwg files, without all the references etc to Civil3D projects etc.
Is there a way I can configure Vault for simple .Dwg file management as it works with standard AutoCAD or AutoCAD Map?
Jim Williams
Product Support
Richard.Rankin
Message 2 of 14 (180 Views)
Re: Vault for simple .Dwg file management with Civil3D
10-07-2011 04:23 AM in reply to: jkwilliams
Can you tell me why you would need to do this?
What is it about the interface that makes you want to revert to the base AutoCAD functionality?
Richard Rankin
Data Management Support Specialist
Autodesk Support
Active Contributor
jkwilliams
Message 3 of 14 (166 Views)
10-09-2011 03:00 PM in reply to: jkwilliams
Richard,
Thanks for your interest here.
As mentioned earlier I need simple Check-In and Check-Out of .Dwg files, without references to "Civil3D Projects".
The standard AutoCAD interface does not require the user to select a Project, and I would like my Civil3D users to use the same as my AutoCAD Users, for support and training purposes.
Jim
Product Support
Richard.Rankin
Message 4 of 14 (150 Views)
10-11-2011 01:41 AM in reply to: jkwilliams
Hi jkwilliams,
I asked this question internally to see if we could offer any alternative suggestions. The bottom line is, if your users are using C3D features like Points, Point Groups, Intersections, they should be using the C3D Vault Addin Interface. The C3D Vault supports those features.
If the users are not using those C3D features, they can close C3D and run the Vanilla AutoCAD profile to get the standard AutoCAD Vault checkin interface.
I hope this helps.
Richard Rankin
Autodesk Support
Active Contributor
jkwilliams
Message 5 of 14 (138 Views)
10-11-2011 02:11 PM in reply to: jkwilliams
Richard,
Thanks for your comments here.
My users of Civil3D will be usign the software for Survey related work, preparing mainly Parcel deposited Plans, but will use Points groups, and some basic TIN surfaces, but will not need to share C3D objects.
I do however want thier data backed up in our Vault configured for AutoCA use with other internal departments.
Why would I use the Vautl for Civil3D, when all I need is simple Check-In and Check-Out?
Id I don't want to actual share C3D Objects, why would I use it?
Jim
Active Contributor
jkwilliams
Message 6 of 14 (137 Views)
10-11-2011 02:14 PM in reply to: jkwilliams
Richard,
You wrote earlier:
I assume you mean use the AutoCAD "2D Drafting & Annotation" Workspace?
I have tried this, and I still get prompted to select a Civil3D Project, which is not what I want.
Any way around this "Project" issue with Civil3D?
Jim
Employee
chearhuat
Message 7 of 14 (132 Views)
10-11-2011 06:48 PM in reply to: jkwilliams
Hi jkwilliams,
In native ACAD, vault uses XREF ESW (Enhanced Secondary Window) for all the vault operation. Probably you could try it out...
Chear Huat.
Chear Huat
SQA Analyst
DLS- Data Management
Be sure to check out the Vault Help Wiki!
Active Contributor
jkwilliams
Message 8 of 14 (127 Views)
10-11-2011 11:17 PM in reply to: chearhuat
Chear,
Thanks for the suggestion of using XREF ESW (Enhanced Secondary Window).
How would I access this within Civil3D 2011?
Jim
Employee
chearhuat
Message 9 of 14 (119 Views)
10-12-2011 12:53 AM in reply to: jkwilliams
Hi Jim,
You could invoke XREF ESW via commandline, 'XREF'. Do note that 'XREF' will have no information of C3D project, and all its contained file relationships.
Chear Huat.
Chear Huat
SQA Analyst
Active Contributor
jkwilliams
Message 10 of 14 (118 Views)
10-12-2011 01:38 AM in reply to: jkwilliams
Chear,
I have run the XREF command, and there is no clear way of doing a Check-In or Check-Out in Vault with no reference to a Civil3D Project.
If I select the file in the XREF Window, I am still prompted to select a Civil3D Project.
How do I work around this?
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
