Vault General
Valued Contributor
Message 1 of 6 (258 Views)
Accepted Solution
Vault back up validation test
258 Views, 5 Replies
01-13-2013 10:56 PM
good day.
I want to test my filestore back up, without affecting my companies current set up, or database,
I want to see if we were to loose the data, is the back up actually running, and rerstoring correctly,
how can I replicate this.
kind regards
Employee
olearya
Message 2 of 6 (241 Views)
Re: Vault back up validation test
01-14-2013 05:41 AM in reply to: jacoj
Hi there,
This is a very good idea and we encourage users to test this regularly, in a perfect world it would be great for each company to have a dedicated server for testing backups and migrations etc.  Of course we realize this is not always possible but to accomplish what you want safely you would need to utilize a second server set up similarly to your production server.  (If you restore on your production server and it fails - this is bad! :smileyhappy:)
While you should not need the same machine specifications as your production server it will of course need to meet the Vault system requirements and you should have the same version of SQL as used on the production server.
Hope this helps.
Allan
Product Manager
Autodesk, Inc.
Valued Contributor
Message 3 of 6 (223 Views)
01-15-2013 11:09 PM in reply to: jacoj
Thank you,
As i thought,
thank you for emphasizing the SQL, I did not think of that
Distinguished Contributor
Message 4 of 6 (217 Views)
01-15-2013 11:40 PM in reply to: jacoj
What kind of backup did you perform? Only a filestore backup?
Normally, the best an secure way to perform a backup from the Vault is to use the ADMS Console in command line mode:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0098-Autodesk98/0141-Command_141
This kind of backup will backup Database + filestore.
Have a nice day.
Valued Contributor
Message 5 of 6 (210 Views)
01-16-2013 12:24 AM in reply to: xdumont
Hi
we back up the database and filestore,
the one overides the other one daily,
so what I want to do is replicate this, ( server and client)
delete the test vualt, and reinstate the actual back up from the tapes to the test machine,
to see if our back up system will be able to be recovered on a fruquent basis....
Valued Contributor
Message 6 of 6 (184 Views)
02-04-2013 09:27 PM in reply to: jacoj
can you guys assist me how to rreplocate this without affecting my database.
I want to test the back up, on a spare server,
do I need to replicate my server, and run the back up there than?
how do I restore the back up then to compare and see if the back up is really successful as the log files stated?
is there white papers or documentation on this procedures.
kind regards
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
