Is it possible to rename an Xref in Vault Pro 2014 without having to repath the actual drawings (Where Used) individually by having to check out the drawings and repath...?
Cheers,
David
Solved by minkd. Go to Solution.
Yes. When you later download one of the impacted drawings (where-used), vault will automatically repath the reference for you.
-Dave
