Vault General
*Expert Elite*
scottmoyse
Message 1 of 15 (505 Views)
Vault User Interface Inconsistencies
505 Views, 14 Replies
02-29-2012 03:01 AM
I'm starting a series of blog posts highlighting the UI issues in Vault. As I have the time and come across them I will be posting on the blog.
Intro:
http://designandmotion.net/autodesk/autodesk-vault-love-hate-relationship/
here is the first post:
http://designandmotion.net/autodesk/vault-vault-ui-property-conditions/
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Employee
mikel.martin
Message 2 of 15 (479 Views)
Re: Vault User Interface Inconsistencies
02-29-2012 06:44 AM in reply to: scottmoyse
(repost due to spelling error)
Hi Scott,
First, let me say I look forward to the feedback. We are always glad to receive constructive feedback from our customers. I plan to add your blog to my rss feeds so I can be sure not to miss the conversation.
On another note, as someone that cares about this issue, would you be willing to be considered a regular contact for our UX team and give feedback on planed changes?
If you (or anyone else) is interesting proving feedback to our UX team please send me your contact information and I will add you to our list. My email is mikel.martin@autodesk.com.
Mikel Martin
User Experience Architect
PLM / Data Management
Autodesk, Inc.
*Expert Elite*
scottmoyse
Message 3 of 15 (465 Views)
02-29-2012 11:23 AM in reply to: mikel.martin
Thank you for taking the time to reply Mikel. I have sent you an email
Cheers
Scott Moyse
Message 4 of 15 (459 Views)
02-29-2012 12:11 PM in reply to: scottmoyse
Hi Scott, Here's one: When using the "Assign Category" tool, I have two options to move the Available Property Definitions across to the Assigned Property Definitions box. Both "drag 'n drop" and the "Add>>" button work. When using the "Configure Data Card" however, I can only use the "Add ->" (note that the arrows are different, >> vs ->) button to move the Properties to the Data Card box. Drag 'n drop doesn't work. And then yet another difference, in the "Item Export" wizard, there is no "Add" button at all. I can ONLY drag 'n drop the Vault Professional Attributes to the Export file box. See attached screenshots. Go figure....
*Expert Elite*
scottmoyse
Message 5 of 15 (457 Views)
02-29-2012 12:17 PM in reply to: knacsol113
Great start, that one is a proper can of worms, I will elaborate on it in my post. Cheers!
Cheers
Scott Moyse
cliff.haynes
Message 6 of 15 (422 Views)
03-01-2012 09:06 AM in reply to: scottmoyse
I have one. Sometimes when using the Inventor Add-In I attempt to check in an assembly containing library parts or assemblies. For some reason Inventor thinks those library parts have changed, and when I try to check the assembly in it fails due to not being able to save those 'changed' library parts. To get around this, I close the file, which brings up the dialog asking if I want to check the assembly in (provided it is already in vault and I have it checked out of course). If I click 'Yes', it should give me grief about not being able to save the library file/assembly, but instead it ignores that and takes me to the check in dialog, where I can successfully check in the assembly.
This is with Vault Collaboration 2012. Has anyone else experienced this?
*Expert Elite*
scottmoyse
Message 7 of 15 (412 Views)
03-01-2012 12:02 PM in reply to: cliff.haynes
yes but the close workaround is a handy bug. There are a number of reasons why this happens check these out:
http://crackingthevault.typepad.com/crackingthevault/2010/10/why-does-my-inventor-assembly-always-ne...
http://crackingthevault.typepad.com/crackingthevault/2010/10/changes-have-been-made-to-some-assembly...
But you can check out my article and other posts about vault here:
http://designandmotion.net/autodesk/mfg-pages/inventor/inventor-navigating-the-library-assembly-mine...
Some videos for it are here: http://designandmotion.net/autodesk/mfg-pages/inventor/inventor-vault-library-videos/
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 8 of 15 (388 Views)
03-03-2012 02:20 AM in reply to: knacsol113
Thanks a lot for posting that "un named" :-) I have created a blog post here:
http://designandmotion.net/autodesk/autodesk-vault-vault-ui-assign-configure-add-dialogues/
I added a few more cases but didn't include the item import example, since that format works well for mapping out the properties between the source file and the destination Items.
I hope you like it.
If you have any more example fire them through.
Cheers
Scott.
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 9 of 15 (349 Views)
03-12-2012 10:40 PM in reply to: mikel.martin
This issue relates to renaming folders
http://designandmotion.net/bug-report/autodesk-vault-vault-ui-rename-folder
Cheers
Scott Moyse
*Expert Elite*
scottmoyse
Message 10 of 15 (312 Views)
04-05-2012 05:00 PM in reply to: scottmoyse
This one covers some small issues when creating a New Folder in the Vault Client
http://designandmotion.net/autodesk/autodesk-vault-vault-ui-folder/
Cheers
Scott Moyse
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
