Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault & Task Scheduler (Create DWF)
9 REPLIES 9
Message 1 of 10
580 Views, 9 Replies
What's the proper method to add a task(s) to task scheduler to checkout, create DWF and check back in. I used autoloader to add the files without associated DWF's.
9 REPLIES 9
Message 2 of 10
I typically do a manual check out of files - then simply run the check in
task on them to get the DWF created. even if no real changes happen it
should create a DWF for you.
Brian Roepke
Manager, Customer Success, Data Management
"TRambach" wrote in message news:5821753@discussion.autodesk.com...
> associated DWF's.
Message 3 of 10
That's what I thought... when it went to check back in there was no changes to the files and it simply undid the check out? I thought this was odd.
Message 4 of 10
Sorry to hijack this thread.
Brian, any ideas as to why sometimes default views of DWF's are zoomed in on
a ortho view, instead of a full iso view.
See this thread.
http://discussion.autodesk.com/adskcsp/thread.jspa?messageID=5815281
Thanks.
Mike
Message 5 of 10
Yes - when files are published non in the context of an open window (for
example the IPT DWF for some component in an assembly) the view for that DWF
is ambiguous and therefore becomes random.
It's something we would all like to fix but haven't been able to address it
yet.
Brian Roepke
Message 6 of 10
did you get the DWF?
Brian Roepke
"TRambach" wrote in message news:5822018@discussion.autodesk.com...
> odd.
Message 7 of 10
Thanks!
Mike
; "Inc.)" wrote
in message news:5822341@discussion.autodesk.com...
yet.
Brian Roepke
Message 8 of 10
No DWF, it alomost appears as an undone checkout.
Message 9 of 10
Brian
I too have a number of dwg files created in AutoCAD with no dwfs.I have tried to use the task sheduler, but on check in get a DBX CAS 4 error.Is it possible to create dwf files of AutoCAD dwg files using the task scheduler
Message 10 of 10
dhorning
does Vault have Task Scheduler so i dont have to open the files onto my computer or do I have to have the IDWs on my computer and then do Task Schedular?
