Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Server Disk?
3 REPLIES 3
andrew.warren
212 Views, 3 Replies
Vault Server Disk?
I am getting ready to install Vault 2013 on a new server. We have both INV and ACADE in various flavors and quanities. I was wondering is it OK to use the Vault Server disk from ACADE to install the server? At one time I was thinking way back when it would cause a problem with Inventor?
We have
Factory Design Suite Standard thr Ultimate
Product Design Suite  Standard thr Ultimate
AutoCAD Electrical
Andy Warren
BCDesign@bellsouth.net
3 REPLIES 3
herrerh
in reply to: andrew.warren
Yes, as long as the version of Vault is the same as what is provided on the Suites media.
For exampeld if you have AutoCAD Electrical 2012 and your suites are 2012 it wont be a problem.
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
andrew.warren
in reply to: herrerh
My plan is to use the 2013 Vault since we just received it, with the 2012 Inventor until we upgrade the projects to 2013. I know this is OK from a Vault stand point is this still OK from an install? I did this on a test machine locally and it worked fine. Am I still OK to use the Electrical for the main Vault install? I think I am just want to check...
Andy Warren
herrerh
Yes, that will work fine.
Hywell Herrero
Product Support
Autodesk, Inc.
