Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Server 2014 to 2015 database migration fails
11 REPLIES 11
Message 1 of 12
OutFrontPS
954 Views, 11 Replies
Doing a "dry run" test (a cloned VM) of migrating our vault to 2015. This is our standard procedure we've been doing for many years with much success.
The 2014 to 2015 upgrade however, is giving us grief. After the install, the first time you open ADMS Console it of course migrates/upgrades the databases. When it attempts to do our database - it fails with the error:
"The Delete Statement Conflicted with a reference constraint"
See full error attached in picture below. I've tried twice now (2 separate clones) and the problem happened both times. Obviously we're going to hold off upgrading the production system until we know how to get by this problem.
Any thoughts/help would be appreciated!
11 REPLIES 11
Message 2 of 12
OutFrontPS
in reply to: OutFrontPS
It seems very similiar to the issue outlined here:
http://knowledge.autodesk.com/sites/default/files/file_downloads/ts1101007_readme.txt
But that's a hotfix for 2009 - even though it fairly accurately describes our problem
Message 3 of 12
OutFrontPS
Here's the full error out of the console log.
Connectivity.Application.VaultManager.ServiceException: The DELETE statement conflicted with the REFERENCE constraint "FK_ItemToComp_ComponentIterationID". The conflict occurred in database "ACPS_MANU", table "dbo.ItemToComp", column 'ComponentIterationID'.
Cannot insert duplicate key row in object 'dbo.BOMComponent' with unique index 'IX_BOMComponent_1'. The duplicate key value is (4549, 7F487859-42AF-D311-E358-56BF4DD47FAC).
The statement has been terminated.
The statement has been terminated. ---> System.Data.SqlClient.SqlException: The DELETE statement conflicted with the REFERENCE constraint "FK_ItemToComp_ComponentIterationID". The conflict occurred in database "ACPS_MANU", table "dbo.ItemToComp", column 'ComponentIterationID'.
   at Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
   at Connectivity.Core.Database.SqlAccess.ExecuteNonQueryInternal(SqlCommand cmd)
   at Connectivity.Core.Database.SqlAccess.ExecuteNonQuery(CommandType commandType, String[] commandText, Int32 commandTimeout, SqlParameter[] commandParameters)
   at Connectivity.Core.Database.SQLScript.ProcessBatches(LocalWorkgroupContext context, String[] batches, Int32 commandTimeout, SqlParameter[] parameters)
   at Connectivity.Core.Database.SQLScript.ExecuteScriptString(String script, Int32 commandTimeout, SqlParameter[] parameters)
   at Connectivity.Core.Operations.Migrate.ExecuteTransactedMigration(Migration currentmigration)
   at Connectivity.Core.Operations.Migrate.Execute()
   at Connectivity.Core.Services.KnowledgeVaultService.MigrateKnowledgeVault(String vaultName, OnProgressDelegate onProgress)
   at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
   at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
   --- End of inner exception stack trace ---
   at Connectivity.Application.VaultManager.ProgressCommand.Execute()
   at Connectivity.Application.VaultManager.MigrateAllCommand.MigrateVaults(LoginInfo dbLogin)
26/05/2014 6:00:24 PM Migration of 'ACPS_MANU' failed: The DELETE statement conflicted with the REFERENCE constraint "FK_ItemToComp_ComponentIterationID". The conflict occurred in database "ACPS_MANU", table "dbo.ItemToComp", column 'ComponentIterationID'.
Message 4 of 12
johannes.bauer
Hello Riese,
thanks for engaging with Autodesk in the forums.
For this kind of issue it is the best to open a support case in subscription center for product support to help you.
Thanks!
HTH
Johannes Bauer
Customer Technical Successt
Message 5 of 12
kolesaa
Hi rise.
I have the same problem, create a case (09700321 Link), but Autodesk is silent. How did you solve the problem?
Thank.
Message 6 of 12
david_j2_myers
in reply to: kolesaa
Similar error here as well.  Case submitted  on 7/7/2014 (09770639).  Escalated to development for resolution. No resolution as of 7/18.
Message 7 of 12
Same issue here. Any fix yet?
Message 8 of 12
Case # 09910479.  Is there a fix for this??!!??
Message 9 of 12
OutFrontPS
in reply to: david_j2_myers
Autodesk looked at our data set after we opened a support ticket and wrote a script to fix it.
After that the migration went OK.
Best Regards,
Riese Heemskerk
Out Front Portable Solutions
905-563-9790 ext:234
1-800-282-1239
riese@outfrontps.com
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Message 10 of 12
In our case after two months of (not sure what we were waiting) Autodesk
suggested remote session.
AFAIK they found some cyclic dependency in one of SQL tables.
After removing some raw the migration was successful.
Message 11 of 12
per_jonsson
Hi
Migration from 2014 to 2015 ended with the same issue. Where can we find the database script mentioned in this thread?
/Regards Per Jonsson
Message 12 of 12
per_jonsson
Hi
I found the solution. Download DM1904923 from Autodesk and do an upgrade.
/Regards, Per Jonsson
