I have a severely crashed Vault/SQL database, where I could save some time rebuilding a new Vault by exporting the configuration. Unfortunately, the Service Pack 1 for Vault 2013 was not installed - so the Export Bug is present. Unfortunately, again, it is not possible to migrate the database after SP1 - because of incorrect entries in the database.
I need to delete the foreign key FK_ContentSourceIndexStatus_Entity, but I can't find it anywhere in the databases!
Where is it???
----------- Grindstone to Grindstone SP1 migration ----------- -- -- --Potential Replication conflicts - Content Source Index Status (ContentSourceId, ContentSourceIndexStatus) moved out of FileMaster into new Table [ContentSourceIndexStatus] --To avoid potential conflict where a Property File Re-Index can be updating ContentSourceId, ContentSourceIndexStatus on table [FileMaster] on one workgroup --while the file is curently Checked Out on another workgroup - the result being that the FileMaster update by the Re-Index can potentially "remove" Checkout info on the other workgroup --First, create new ContentSourceIndexStatus table CREATE TABLE [dbo].[ContentSourceIndexStatus] ( [EntityId] [bigint] NOT NULL , [ContentSourceId] [bigint] NULL, [ContentSourceIndexStatus] [bit] NULL, CONSTRAINT [PK_ContentSourceIndexStatus] PRIMARY KEY CLUSTERED ( [EntityId] ASC ) ON [PRIMARY], CONSTRAINT [FK_ContentSourceIndexStatus_Entity] FOREIGN KEY ([EntityId]) REFERENCES [dbo].[Entity] ([EntityId]) ON DELETE CASCADE NOT FOR REPLICATION, ) ON [PRIMARY] --Move current ContentSourceId, ContentSourceIndexStatus values from FileMaster using the tip iteration of the master --Like ContentSourceProperties we store the tip iteration (rather than the master Id) to avoid conflicts with Replication. INSERT INTO [dbo].[ContentSourceIndexStatus] (EntityId, ContentSourceId, ContentSourceIndexStatus) SELECT m.TipIterationId, fm.ContentSourceId, fm.ContentSourceIndexStatus FROM dbo.FileMaster fm INNER JOIN dbo.Master m ON m.MasterId = fm.FileMasterId WHERE m.TipIterationId IS NOT NULL --We also need to create an entry where TipCommitted <> TipIteartion (e.g. for any checked out files) --Like ContentSourceProperties we store both the TipCommitted and TipIteartion version until file is Checked In or Undone INSERT INTO [dbo].[ContentSourceIndexStatus] (EntityId, ContentSourceId, ContentSourceIndexStatus) SELECT m.TipCommittedIterationId, fm.ContentSourceId, fm.ContentSourceIndexStatus FROM dbo.FileMaster fm INNER JOIN dbo.Master m ON m.MasterId = fm.FileMasterId WHERE (m.TipIterationId IS NOT NULL AND m.TipCommittedIterationId IS NOT NULL) AND m.TipIterationId <> m.TipCommittedIterationId go
Aha, the table and the foreignkey is created by the upgrade script.
Is it possible to edit the .SQL files used by the SP1 upgrade script? I do not need this database to be in a consistent state, I only need to be able to apply SP1 to be able to export the configuration (Categories, Lifecycles etc).
Do not modify the database!! Once you do that we cannot support you, and will very likely create more problems for yourself.
The right thing to do in a situation like this is to contact product support.
-Dave
My intention is only to edit a database that will never be used again. It will only be used to export the vault configuration.
The database is broken, as parts of it could not be recovered after a RAID failure (2 drives of 5 failed). I managed to run a SQL repair with data loss, but Service Pack 1 will not install - probably because of incorrect db entries.
If all you care about is exporting the configuration, then why not restore your last good backup and export from there?
-Dave
