Vault General
Active Member
Message 1 of 3 (247 Views)
Vault Revision table will not insert into .idw
247 Views, 2 Replies
02-07-2013 08:06 AM
I am trying to enable the Revision table for Vault into my .idw's  As I understand the procedure is to go to the Behaviours tab in Vault settings, under properties click on Revision Table and then tick the Enable Revision Table Control tickbox.
After this you can choose what header columns you want and what properties are mapped to them.
When I try to insert the vault revision table into my .idw it gives me this error message.
Revision Table settings not found: the activevault has not been configured with required integration settings.  Please contact your administrator.
I have researched this and it says that it gives me this error message when I have not ticked the Enable Revision Table Control tickbox in my Vault settings.
What am I doing wrong?
I am attaching screenshots of what  my vault looks lik with regards to the vault revision table and settings.
cbenner
Message 2 of 3 (234 Views)
Re: Vault Revision table will not insert into .idw
02-07-2013 09:58 AM in reply to: Aldred
Do you have a valid Revision Table style setup in Inventor, which matches the field settings that you selected in Vault?  Is that set as the default Revision table in your Object Defaults?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Active Member
Message 3 of 3 (207 Views)
02-10-2013 11:30 PM in reply to: cbenner
Hi Chris,
It is working now.  It seemed to be the fields in vault and Revision Table style setup in Inventor that was conflicting.
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
