Is anyone using the Vault Revision Table? Vault Pro 2013 or anything close? Have you gotten it to work?
I have tried it with the default settings, and with picking standard and/or custom properties. Every time in Inventor that I place a Vault Rev table, it comes in with the settings of my custom "regular" revision table. What do I do to get the Vault table to come in using the properties I set up for it IN VAULT?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by yingkit(Autodesk). Go to Solution.
Think im making slow progress, havent gotten it to work but It's alot harder than it needs to be.
it's not like every single drawing needs to be issued for construction needs a titleblock and rev table, but using civil 3d i might be dreaming.
From this thread I've gotten it close to working, just need to figure out why the Job Processor is looking at the wrong server.
http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-Revision-Table-Integration/td-p/3134818
Chris Benner
Hi Chris,
I would like to recommend this article "Setting Up Vault Revision Tables" which also includes a video clip.
The Revision Table settings in Vault does not control the settings in the revision table that is placed in Inventor. Rather, we enter the exact words used in the drawings' revision table column for the Column Header value while configuring the Revision Table Settings.
Kit
Hi cbenner,
Ying-Kit is right, the Vault revision table does not control the styles of the Inventor drawing.
You would require to custom the Revision Table styles in the drawing templates within your workgroup.
I have just posted a link on how this can be done:
http://forums.autodesk.com/t5/Autodesk-Vault/Vault-revision-table-and-Autocad/m-p/3519888#M43147
Hope this helps.
Thank you guys for your help, I've managed to push through this challenge and got the table working. That was a major hurdle in my DMS plans.
Chris Benner
