Same problem here; we did a migration from Inventor Suite 2009 to Inventor 2010 Suite including Vault on our workstations. We are running ADMS on a dedicated server (Small Business Server 2003) which has also been migrated from 2009 to 2010. After checking out a drawing, changing the drawing a little and checking it back in, all drawing properties were gone. After checking the drawing out again, to check whether the properties are still present in the iProperties, we discovered they were still present. Checking it back in again didn't help. Checking the settings of Vault (manage properties) showed that the settings didn't change after the migration. The desired properties remain "In Use" as they were initially. A 'rebuild indexes' on the server didn't help also. This is quite frustrating because our colleagues use the search capabilities of the vault to find projects with specific properties. Please, help is greatly appreciated.
See attachment for screenshots.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
