Instead of opening the drawing or modell in a neat little window when pressing the view button, the vault application launches Autocad or Inventor to view the files.
Anyone else experienced the same problem and found a solution?
//Tom Wikberg
What version of Vault are you using? Do you have DWG True View loaded on your machine?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I'm running vault professional 2014 with True View 2014 and Design Review 2013 Installed.
Hey Tom,
We are investigating this - believe it relates to 64 Bit machine compatibility issues. Will update you as more information becomes available.
Do you have visualisation (dwf/dwfx) files available? The View in Window command usually views the visualisation file but without one, the native data is opened.
Show the Vizualisation Attachment column in Vault Professional. I suspect for these CAD files the status will be None. Use Update to create a dwf and try again.
Paul.
Yeah, i have visualisation enabled, and the dwf files are published to a shared network drive.
The Visualisation files are system generated and i can see and interact with them in the preview tab.
So there must be something else messing with our view in window.
I think it's server related due to the fact all vault users on the same server are having this problem.
//Tom
Yes, experiencing similar issue with VP2014. When we "View in Window" it opens Inventor View. It used to open Design Review.
The View tab is working as expected, so a dwf is present in Vault.
This is a 64 bit machine.
