Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Professional View in Window Problem
8 REPLIES 8
Message 1 of 9
tomwikberg
1245 Views, 8 Replies
Instead of opening the drawing or modell in a neat little window when pressing the view button, the vault application launches Autocad or Inventor to view the files.
Anyone else experienced the same problem and found a solution?
//Tom Wikberg
8 REPLIES 8
Message 2 of 9
cbenner
in reply to: tomwikberg
Message 3 of 9
tomwikberg
in reply to: cbenner
I'm running vault professional 2014 with True View 2014 and Design Review 2013 Installed.
Message 4 of 9
olearya
Hey Tom,
We are investigating this - believe it relates to 64 Bit machine compatibility issues.  Will update you as more information becomes available.
Allan
Product Manager
Message 5 of 9
Do you have visualisation (dwf/dwfx) files available? The View in Window command usually views the visualisation file but without one, the native data is opened.
Show the Vizualisation Attachment column in Vault Professional. I suspect for these CAD files the status will be None. Use Update to create a dwf and try again.
Paul.
Message 6 of 9
tomwikberg
Yeah, i have visualisation enabled, and the dwf files are published to a shared network drive.
The Visualisation files are system generated and i can see and interact with them in the preview tab.
So there must be something else messing with our view in window.
I think it's server related due to the fact all vault users on the same server are having this problem.
//Tom
Message 7 of 9
steveh3
Yes, experiencing similar issue with VP2014. When we "View in Window" it opens Inventor View. It used to open Design Review.
The View tab is working as expected, so a dwf is present in Vault.
This is a 64 bit machine.
Inventor---Vault Professional
Message 8 of 9
steveh3
Tom...any resolution yet?
Message 9 of 9
olearya
in reply to: steveh3
Hi Gents,
This issue is addressed in SP1 here.
Allan
Product Manager
