Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Professional 2015 and Inventor 2012.
2 REPLIES 2
AlbertoTorres
689 Views, 2 Replies
You may have installed Vault Professional 2015 and working with Inventor 2012 Part Vault Professional 2015 client is compatible with Inventor 2012. It would have to install Vault Professional 2012 Client to connect to Vault Professional Server 2015. It is possible? If possible, and by that installation procedure should be followed? Thank you.
2 REPLIES 2
DarrenP
in reply to: AlbertoTorres
if it works
you should be able to log in from the vault pro 2012 client to the vault pro 2015 server
you shouldn't have to install anything
i know 2014 client to 2015 server works
haven't tried anything lower
DarrenP
DarrenP
in reply to: DarrenP
from the help
Support for Prior Vault Clients and Add-ins
  • The Vault 2015 ADMS supports the use of any Vault 2013 release and Vault 2014 release clients which match the Vault edition of ADMS.
  • The Vault 2015 ADMS supports the use of any Vault 2013 release and Vault 2014 release Add-Ins.
  • It is not recommended to administer Vault or Global settings through an older client. All administration of Vault and Global settings should be done through ADMS Console or a Vault client of the same release as the Vault server.
  • New functionality available in Vault 2015 will not be available in older Vault clients and Add-Ins.
  • Vault 2015 clients no longer display the ownership icon when another site has ownership of an entity but the lease has expired. As a result older clients will also not see the ownership icon. However, older Vault clients do not automatically request ownership if the other site's lease has expired as Vault 2015 clients do. As a result, Users with older Vault clients may experience errors opening, checking out, or performing other operations on files which appear to be owned locally. In these cases, the user should manually request ownership and try the operation again.
  • Some functionality in a Vault 2015 client may not work when only an older version of the CAD application is installed or if an older version of the CAD application was last run. Running Inventor View 2015 or the 2015 version of the CAD application and then retrying the operation may resolve the issue.
DarrenP
