Vault General
Active Contributor
Message 1 of 2 (275 Views)
Accepted Solution
Vault Pro Backups and MS SQL Server Guest Account for MSDB database
275 Views, 1 Replies
11-07-2012 12:49 PM
In MS SQL Server their existing several system databases (master, model, msdb, tempdb).  During a customer IT security scan of the Vault SQL server it reported back a security hole.  For these system databases their exists a default SQL Guest account under their security settings.  This account raises as a security risk by the scanners.  The customer went and disabled this SQL Guest account for each of those system databases (as they have done for their other SQL servers), but this time for Vault, the Vault backups stopped working.  Once this SQL Guest account was reenabled the Vault backups continued to work again.
My question is...does Autodesk Vault require this SQL Guest account to perform operations like the Vault backup and/or other operations?
We found some documentation from MS that indicates that this may be some sort of bug in SQL 2008 and not to disable it.  But my customer wants to hear from Autodesk first on this issue!
Thank you!
John
JD
Board Manager
Message 2 of 2 (270 Views)
Re: Vault Pro Backups and MS SQL Server Guest Account for MSDB database
11-07-2012 01:42 PM in reply to: jdow
John,
Vault doesn't require this account SQL does.  Please have your IT department use the SQL Management Studio and perform a backup of all databases through the studio.  You should have the same issue.
See this article: http://support.microsoft.com/kb/2539091
Irvin Hayes Jr
Product Manager
Autodesk, Inc.
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
