Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2015 - Receiving Error 109 on Item Update
22 REPLIES 22
Message 1 of 23
Esky99!
1396 Views, 22 Replies
We are receiving Error 109 on updating some items.
It states the Server Log file needs to be investigated.
Is this a known issue?
22 REPLIES 22
Message 2 of 23
Esky99!
in reply to: Esky99!
Refer to Server Log attached
Message 3 of 23
minkd
I suggest opening a product support case to figure this one out.
-Dave
Dave Mink
Fusion Lifecycle
Message 4 of 23
tmoney2007
I'll save you a little time... "Are you up to date with your service packs and hot fixes?" "Check all the files out and back in again and retry"
There's something wrong with a record in the table where some of the BOM information stored (is what it looks like).
When I try to troubleshoot these issues, I generally try to assign/update the items for the children of the assembly, on of those will probably fail with the same error. Then go to all the children of that assembly and repeat.  Eventually you may get to a part or assembly where something looks off or you'll reach the bottom of the file structure. If you check that one out and back in, it may fix it.
The thing to remember about items is that assigning the item to an assembly will trigger Vault to check if any of the children are out of date and update them as well.  There is a more than fair chance that the file causing this problem ISN'T the assembly you are trying to assign, but something at some level below.
If you get a real solution from support, please post it up here.  My company has been implementing item master and it has been a nightmare.
Message 5 of 23
Esky99!
Thanks for your comments.
Totally aware of all of your comments. We have been using item master since product stream was first released.
Issue on this item has only arisen since installing 2015.
I have pinpointed the sub assembly in question. I am going to unlock each item and update each part and assembly within. Hoping this will fix the issue.
I've been told someone logged in as admin within inventor vault and checked out all files and saved them while they were locked in item master. I will need to unlock all items to update. Nightmare.
I'll also await comments from Autodesk.
Message 6 of 23
Esky99!
in reply to: minkd
Hi Dave
There is a product support case number on this.
Any chance in chasing this up. Getting a bit urgent now.
Paul
Message 7 of 23
minkd
I'm sorry that Product Support hasn't gotten back to you yet.  It is possible that they are swamped right now and hopefully they will be getting to you soon. When they do get in contact with you, make sure you get them the vlog you posted here; and they may ask for a copy of the db from a recent backup so they can try to reproduce the issue. I'm guessing they will want the backup because they likely won't be able to reproduce the problem otherwise.
-Dave
Dave Mink
Fusion Lifecycle
Message 8 of 23
Esky99!
in reply to: minkd
Hi Dave
Still no response here.
This one is urgent. I have other message listings that arent so urgent. But this one is.
Paul
Message 9 of 23
minkd
I have no ability to affect the order or priority of cases in Product Support. All I can suggest is to contact them again and make sure they understand the severity of your situation.
-Dave
Dave Mink
Fusion Lifecycle
Message 10 of 23
Esky99!
Hi Dave
All good for time being. I have a workaround until Autodesk team fix issue.
Regards
Paul
Message 11 of 23
mthomas
We're now experiencing this issue to since moving to 2015, so far only a handful of items but who knows how many are affected.
It's been logged with Autodesk Tech Support [PID: 09631692]
What "workaround" are you using?
Mike
Mike Thomas
Tags (1)
Message 12 of 23
Esky99!
in reply to: mthomas
Details removed as Autodesk is working on a fix.
Message 13 of 23
mthomas
Its gone from a small problem to an epidemic very quickly, the number of items that we can not update nor change state has become too long to list.
Mike Thomas
Message 14 of 23
johannes.bauer
Mike, please open a case with product support so we can have a look at your issues.
Thanks.
HTH
Johannes Bauer
Customer Technical Successt
Message 15 of 23
mthomas
in reply to: johannes.bauer
It was logged last week PID: 09631692
Mike Thomas
Tags (1)
Message 16 of 23
Esky99!
If this doesn't rate as a critical issue, I'm not sure what does........
Message 17 of 23
johannes.bauer
sorry did not see that.
thank you!
HTH
Johannes Bauer
Message 18 of 23
davide.orlando
Hello! Can you help me? Several of our customers have this problem, how can I fix it temporarily? there is already a hotfix?
Thank you for your help!
Message 19 of 23
Esky99!
in reply to: davide.orlando
Hi
Unfortunately I cannot help you. There is no current work around.
Autodesk DEV team are aware and currently working tirelessly to get a fix for this. The sooner the better.
Its a real problem for us, as our item master is linked to our ERP system. We have had to manually switch off the link and add and remove items manually as required.
Message 20 of 23
Good Morning,
you have news about the problem?
We have done the following tests you suggested:
1. Checkout and open the file, save all and checkin into Vault.
   --> Assign Item
2. Select in the Menü <Actions> <Clear item and CO locks> <OK>
   --> Assign Item
3. Launch Autodesk Data Managment Server
   Detach the Vault Database
   Detach the Knowledge Vault Master (KVM) Database
   IISRESET
   Attach the KVM Database
   Attach the Vault Database
4. Take a look of the Attach for controle the WindowsRights.
But have not solved the problem.
Thanks..
