Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Pro 2014 client install failure
3 REPLIES 3
jdow
1505 Views, 3 Replies
Here is the setup log file and error we are receiving when trying to install the VP 2014 client.
Fails near the end of the install. Dialog says error 1309.
Any thoughts?
2013/5/17:19:00:45 PC-=== Setup started on PC===
2013/5/17:19:00:45 PC-Launch
2013/5/17:19:00:56 PC-PageOpen LaunchDialog
2013/5/17:19:01:54 PC-PageOpen LicenseDialog
2013/5/17:19:01:57 PC-PageOpen ProductInfoDialog
2013/5/17:19:01:59 PC-PageOpen ProductSelectionDialog2
2013/5/17:19:02:10 PC-PageOpen FullProgressDialog
2013/5/17:19:02:10 PC-Installing DirectX® Runtime: "E:\Downloads\Autodesk 2014 Software\Vault\Autodesk_VPC2014_ENU_32-64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2013/5/17:19:02:48 PC-Install DirectX® Runtime Succeeded
2013/5/17:19:02:50 PC-Installing Autodesk® Vault Professional 2014 (Client):  TRANSFORMS="E:\Downloads\Autodesk 2014 Software\Vault\Autodesk_VPC2014_ENU_32-64bit_dlm\x64\en-us\VaultProfessional\VaultPro.mst;C:\Users\me\AppData\Local\Temp\_AIC523.tmp\x64\VaultProfessional\VaultPro-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Downloads\Autodesk 2014 Software\Vault\Autodesk_VPC2014_ENU_32-64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Vault Professional 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/5/17:19:21:40 PC-Install Autodesk® Vault Professional 2014 (Client) Failed Installation aborted, Result=1603
2013/5/17:19:21:43 PC-Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
MSI (s) (18:54) [19:21:32:732]: Windows Installer installed the product. Product Name: Autodesk Vault Professional 2014 (Client). Product Version: 18.0.110.0. Product Language: 1033. Manufacturer: Autodesk. Installation success or error status: 1603.
JD
3 REPLIES 3
jdow
in reply to: jdow
JD
jdow
in reply to: jdow
Resolved.
I had to shorten the file path.
JD
in reply to: jdow
Hi, how you shorten that path?
