Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Plot manager gives error when second job is sent within same session
2 REPLIES 2
mdenheijer
379 Views, 2 Replies
I try to send dwf drawings to a PDF printer. This works fine through the vault plot manager. But when I create a second plot job, also to the PDF printer, I get an error.
When I shut down the vault client and reopen Vault, the Plot Monitor is empty. I can now plot 1 job to PDF printer again. THe second job will again fail, and so on and so on.
Does anyone know how to solve this issue?
Error plot monitorJPG
2 REPLIES 2
WillTanner
in reply to: mdenheijer
What happens if you try to plot the main file (IDW, DWG)? Does it work?
mdenheijer
in reply to: WillTanner
 This is not possible. The source file is Revit (Rvt). The sheets of a revit file are stored within this file. If you want to put them into the vault, this is the only way. The vault plugin transforms the sheets into dwf. This does not work the same as Inventor or AutoCAD, where a drawing is a seperate file.
