Been running Vault mirror 2010, now we have upgraded to 2011. Looking for the vaultmirror.exe for 2011. I browsed to the C:\Program Files (x86)\Autodesk\ADMS 2011\SDK\VS9\CSharp\VaultMirror folder, but there is no vaultmirror.exe.
I searched the HD,but still cant find it. Where can I find this file so that I can run vault mirror?
Solved by karthur1. Go to Solution.
It should be in the SDK's 'util' folder. Ironically, I moved it there to make it easier to find.
I'm not sure why you couldn't find it with a hard-drive search.
Doug,
Thanks, I found it there. When I run the vaultmirror.exe, it returns this error.
11/9/2010 10:54:05 AM
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: 227
at Connectivity.Web.Services.DocumentService.FindFileFoldersBySearchConditions(SearchCondition[] conditions, SortCondition[]....
What could be causing this?
Error 227 means there is something wrong with the indexing engine. Since VaultMirror uses the search feature, it can't run if the indexing service is having problems.
I don't know much about the indexing engine, but there are a few other threads on this issue. Just search the group for "227" to find out more.
