Thanks for your post.
It seems that Microsoft.Web.Services3 dll cannot be found. Could you check whether you can see the dll from C:\WINDOWS\assembly folder like the attached pictures.
If you cannot see it, please try install WSE30 via Microsoft WSE 3.0 Runtime.msi (in the installer \\...\VM\x86\Support\WSE30). And then check whether it's fixed.
Kevin
