Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Library Parts are being modified
3 REPLIES 3
jhr2mrr2
204 Views, 3 Replies
We have a mechanical library of parts that we want to use in our assemblies. If you try to check out a part from the library and modify it , vault will not allow this which it is correct in doing so. If we check out an assembly from the vault that contains the part, we can then check out the part, modify it and check it back into vault. I even locked down the part in vault so that it was not available for check out and it could still be modified. This is not a good thing to have happen. How can we solve this problem?
3 REPLIES 3
cbenner
in reply to: jhr2mrr2
jhr2mrr2
in reply to: cbenner
These are parts created in Inventor.
Joseph Robinson
Sr. Mechanical Design Drafter
Kratos Training Solutions
8601 Transport Drive
Orlando, FL 32832
Desk: 407-678-3388 Ext. 8682
Fax: 407-681-8522
www.KratosDefense.com
[cid:image002.jpg@01CD792A.B447BCC0]
***NOTICE*** This e-mail and/or the attached documents may contain technical data within the definition of the International Traffic in Arms Regulations and/or Export Administration Regulations, and are subject to the export control laws of the U.S. Government. Transfer of this data by any means to a foreign person, whether in the United States or abroad, without an export license or other approval from the U.S. Department of State or Commerce, as applicable, is prohibited. No portion of this e-mail or its attachment(s) may be reproduced without written consent of Kratos Defense & Security Solutions, Inc. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to state them to be the views of any such entity. The information contained in this message and or attachments is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. If you are not the intended recipient or believe that you may have received this document in error, please notify the sender and delete this e-mail and any attachments immediately.
jhr2mrr2
We are using Vault Pro 2014.
