I can take control of this file even as administrator, the file has object base secuirty and system overridden security , but I (as the admin) cannot remove any of the security to this file , ehn I go to remove them it says it removed the security but as soon as I swiitch to the other security , all that come back even after I just got done removing the security.....poof they come back
Vault Pro 2014
When you remove the override ACL from the file, it then inherits the ACL from it's parent folder.
So go ahead and remove the override ACL on the file, and then change the ACL on the parent folder. You can do them in the reverse order if you want.
-Dave
