we have installed Vault File Server (AVFS 2014).
Jobs that get created from users connected to the AVFS show up correctly in the Job Queue but the status stays "Pending" unless the Job Administrator selects all those Jobs manually and uses "Take Ownership". After that, the Job Processor works correctly on those Jobs. The Job Processor connects to the main vault installation (and not to the AVFS).
Question: The Ownership is the same for the main Vault Server AND for the File Server as the database is the same! I am not sure how the AVFS regarding the Job Processor should work?! Is there something to configure? How should the user see if the Job got created via AVFS or ADMS?
klaus
Solved by katterbauer. Go to Solution.
Solved by ryan. Go to Solution.
A Job Processor will only process jobs that were submitted locally. So, in your scenario, you would have to have 2 job processors, one logged into each server. See the section about Multi-site support from this page; http://knowledge.autodesk.com/support/vault-products/getting-started/caas/CloudHelp/cloudhelp/2014/E...
