Logged as an admin, I have editted the fields of AVult Revision table.
Tools->Administration->VaultSettings->Behaviour->Vault Revision Table
Modified the fields as needed. My columns are Rev,Description,Date,Engineer,Checked By
But when users, insert a Vault table, the colums are different. They are Zone, Rev,Description,Date,Approved.
Notice that the columns are totally different. Why? Where am I goining wrong.
While we are on the topic, How can I get rid of the Reveion table Title text "Revision"
Hi C1,
The columns order within the Vault Revision Table settings dialog do not impact the layout of the revision table in your drawing in any way. Rather it is a mechanism primarily used for setting up mappings and rules between Vault properties and the columnar information in your drawings.
The layout of the revision table for your drawings are controlled by the Inventor styles defined your drawing (whereby you can make your alteration on the order, widths, etc) However do note that by defining the styles in this drawing, it only affects that particular drawing alone and not any other drawings. My suggestion is that you save your customization in a template and deploy that to all your users so that the content types, layout and size of the revision table looks the same for everyone else on new drawing creation.
Lastly, I don't really understand getting rid of the 'Revision' text.
Do you mean getting rid of the default 'Revision' property mapping to REV (within the Vault Revision Table settings dialog)?
If this is what you meant, then you can't really get rid of it because the Vault Revision Table requires the revision property to know how many revisions there are in the vault. It is a mandantory property and must be mapped to at least one column header. You will also need to have the same column header name in the drawing to have it working.
Let me know if this works for you.
Alan,
That clears and makes good sense.
1. Does this mean that Vault Revision Table Setting dialog can have "as many as" property fileds added and used to map properties between .idw & .ipt.
2. Though we have added several fileds in Step.1. Can we use only FEW of the above fields to use/create a new REV table style??
Yes, you can have many property mappings added and have only a few used in your drawings revision table style.
One of the main reasons this was allowed is for organizations with various languages and/or employ templates with different column header requirements.
In a multi-language organization with the same server, you can setup multiple column headers in different to a single property field, i.e.
REV -> Revision
修订 -> Revision
ИЗМ -> Revision
Thus, when your drawing has either one of the column header above, this feature will automatically understand the mapping and update the Vault revision table as required.
In the same concept, you can have varying Revision Table templates for different type of drawings, i.e. 3 columns for size A drawings and 5 columns for 11"x17" drawings, or maybe different column headers setup for assembly drawings versus a manufactured drawings.
I will try this. Alan - I must tell you, You are such a great support. Thanks.
Alan,
I am extremely sorry to bring this up again. This time I will like to ask one step at a time 🙂
I am having trouble with trying out your suggestion. Here is a basic question. I need a revision table on my drawing.
Which one of the following method should I follow while in a already vaulted IDW drawing.
1. Should I use Annotation>VAULT REVISION TABLE
or
2. Should I use Annotation>REVISION TABLE
C1
Hello C1,
My apologies for I just saw this post after such a long time.
I would recommend using Annotation>VAULT REVISION TABLE.
