Is it possible, in the Vault, to Copy Design a single part or assembly into multiple folder locations?
I have multiple runs of different length piping that I am working with, ideally, It would be nice if I could create multiple folders in the Vault, then when I do a Copy Design, I could select the (1) part/assembly I want to duplicate and place it into each one of the selected folders.
Does anything like this exist? If so, can someone refer me to a step by step procedure?
Thank you!
Welcome!
I don't believe you can do that with Copy Design, at least not all at once. I believe you will have to do multiple copy designs, to get a copy into each of your destination folders.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
That's what I was afraid of.....
Thank you for your input though, It's appreciated!
