Hi
I have made a simple Form to use when filling in iProperties on a idw. This is working fine when I use a "Single user" project. But when I switch to a "Vault" project the forms stops working after placing a view or checking the drawing out. See this video on youtube: http://www.youtube.com/watch?v=pPdIRpVpHuc
Solved by Senthil_Kumar. Go to Solution.
Can you post your .idw file with the form?
If you have not installed Inventor 2012 SP1, you could try installing it. There is a chance that it might fix this problem.
Another thing to try: If your form is Non-nodal (the default setting), try it as a Modal form.
Any news on this issue?
I was able to reproduce the issue and forwarded to development team to take a look.
Thanks for reporting this issue.
As a workaround if you log out from Vault before creating new views and using the form will not throw any error. Can you try that?
If I log out from Vault before creating a new view the form works. But this will take more time then filling in the iproperty manually.. (in the iproperty dialog box..) Please fix as soon as possible..
We should be able to fix the problem (internal number 1427582).
Here's a workaround: after creating a view, create a new part or click on (activate) the window of another open document. If you move to another document and then go back to the drawing, the iLogic browser will refresh and the error will not appear.
Hi
Hopefully there will be a fix shortly 🙂
Here is the Hotfix for this issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18091334&linkID=9242019
