Hello... help!
I've tried the "failed to acquire license" fixes discussed in the other posts... disable\remove IPv6, change server name to IP address in lic file, verified correct mac address, but I'm still unable to get a client connected. I only recieve the "failed to acquire license" message.
Any ideas on how to troubleshoot this?
Here is the status enquiry which looks good...
Status
Flexible License Manager status on Fri 11/18/2011 07:57
[Detecting lmgrd processes...]
License server status: 2700@172.16.20.4 License file(s) on 172.16.20.4: C:\Program Files\Autodesk Network License Manager\VLTM2010srv-ga-vault.lic:
172.16.20.4: license server UP v11.5
Vendor daemon status (on srv-ga-vault):
adskflex: UP v11.5
Feature usage info:
Users of 70800VLTM_2010_0F: (Total of 6 licenses issued; Total of 0 licenses in use)
is this only happening on 1 computer or all of them
DarrenP
It's happening on the first three clients that I have installed.
This is a "new install" (for me) of 2010 Vault.
can they ping the license server by host name?
DarrenP
yes sir... clients can ping the vault server and server can ping clients via host name and IP
did you check your firewall on the server to make sure your fire wall isn't blocking these ports:
The FLEXlm® based version uses the following ports:
DarrenP
yes firewall is turned off on server and client
(thank you for your time by the way)
Here's an error from the server log in the Data Management Server Console...
11/18/2011 8:26:38 AM *******************************************************************
Error: Soap Exception ( mesg-id = 634572015980510795 )
Exception: LicensingError [319] (20)
Stacktrace:
Server stack trace:
at Connectivity.Core.Security.Licensing.a(User A_0)
at Connectivity.Core.Services.SecurityService.SignIn(String userName, String userPassword, String knowledgeVaultName, Boolean readOnly)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Web.Services.SecurityService.SignIn(String userName, String userPassword, String knowledgeVault)
was this working before?
DarrenP
In the root of the vault filestore there should be a file called licensingLog.txt, which may have additional information as why getting a license is failing.
-Dave
i was unable to locate a licensinglog.txt file
this is a "new" installation... i have not previously had Vault installed.
I've entered the Twilight Zone... it's working now and my clients are able to login. Not sure why it's working now...anyways.
THANK YOU for taking time to help with suggestions!
well thats weird
was there a restart of a server or something?
DarrenP
