Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Basic 2014 - Problem
3 REPLIES 3
C.Suclupe
410 Views, 3 Replies
Hi Friends As they are, I would like to help me with the vault 2014 Basic, I'm trying to create a Project in Vault with AutoCAD Plant 3D but I get this notice, you do not have permission to perform operation ... I would like to help me ... Greetings from Peru ....
3 REPLIES 3
Senthil_Kumar
in reply to: C.Suclupe
Hi
Ensure that the logged in User account has the Read and Write access. The user should have minimum - Document Editor (level 1) - Role for creating a file or folder. So check the Roles assigned to that User name.
Refer this page for more information on Roles and access
http://wikihelp.autodesk.com/enu?adskContextId=ID_PSADMINROLELISTHELP&language=enu&product=Vault&rel...
Hope this helps!
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
C.Suclupe
I would like to
help me, every time I want to create a Plant 3D project with the Vault option I get the following warning ... Attached Image .... I hope I can support .... Thanks
Tags (1)
Senthil_Kumar
Sorry for the miscommunication.
Vault Basic is not supported by Plant 3D 2014. You should have Vault Workgroup 2014 or Vault Professional 2014 Server for Plant 3D 2014.
You can get more info from http://docs.autodesk.com/INSTALL_LICENSE/2014/ENU/Autodesk%20Installation%20Help/index.html?url=file...
Senthil Kumar
Autodesk, Inc.
