Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Backup Errors
2 REPLIES 2
ChristianAlanJamesBerg
443 Views, 2 Replies
Vault Backup Errors
We have a vault backup set up using windows task scheduler and it was running great; however, we had to change to vault password and now the backup is throwing an error every time because the original password does not match up. Does anyone know where I go to update the password to the new password so that it will continue to run the backup. I was not the one who set up the backup and he no longer works here so any guess would help. Thanks.
2 REPLIES 2
I'm thinking it should be in the text file you use to set the backup. For me it's here where the asterisks are:-
D:\Program Files\Autodesk\ADMS Workgroup 2013\ADMS Console\Connectivity.ADMSConsole.exe" -Obackup -B"D:\VaultBackUp\Temp" -L"D:\VaultBackUp\VaultBackUpLog.txt" -VUadministrator -VP******** -S -DBSC
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Hi ChristianAlanJamesBerg,
First you should open the windows task scheduler to see what script is it calling for the backup, then update the script as BLHDrafting's post.
Lily
