Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Vault Add-in for Excel not loaded
9 REPLIES 9
Message 1 of 10
karthur1
6130 Views, 9 Replies
When I start Excel (MS office 2007) I no longer have the valut menu bar. Thus, I can't check-in/out from Excel. This has been working fine for about 2 months, then all of a sudden it quits. I have not added anything recently to my system.
I checked the disabled add-ins and Vault shows to be disabled. I tried a repair install, but no luck. I also uninstalled the Vault client and reinstalled. Still shows "disabled" in excel.
Could MS hotfixes that were automatically installed cause this.
I am using Vault 2009.
Any ideas?
9 REPLIES 9
Message 2 of 10
karthur1
in reply to: karthur1
Here is a screen shot of what I am seeing in Excel.
Message 3 of 10
You should enable Excel Vault addin through Excel Option
1 Click on the Office Button, Excel Options, Add-Ins
2 Select COM Add-ins in Manage dropdown list and click Go
3, Enable Autodesk Vault Add-In and reopen Excel
Repair PS/Vault will not enable the Autodesk Vault Add-In for Office 2007 if it's disabled by Office.
Hope this help.
Sandy
Message 4 of 10
karthur1
Sandy,
I tried that yesterday, but I could not find any way to enable them. This morning when I tried it again, I noticed there was a "Disabled Items" in the dropdown list that you mentioned. If I select that, then I can enable the add-in.
It works now, thanks.
Kirk
Message 5 of 10
Jan.v.Ee
Ran into the same issue.
This is what worked for me:
1) Record/memorize the location of the add-in.
2) Remove the Add-in
3) Re-install the Add-in
Message 6 of 10
valdas
in reply to: Jan.v.Ee
Jan.v.ee way also worked for me.
Message 7 of 10
dcaster
My office is using Excel 2013. I cannot even find the add in for Vault  any suggestions?
Message 8 of 10
DarrenP
in reply to: dcaster
here is the one for vault basic 2015
http://knowledge.autodesk.com/support/vault-products/downloads/caas/downloads/content/autodesk-vault...
here is the one for vault workgroup & professional 2015
for vault 2014 this is on the subscription site
DarrenP
Message 9 of 10
dcaster
in reply to: DarrenP
Thank you it appears to work perfectly. Will This also work with Office
2007? My home setup is not quite as up to date.
*Don Caster*
dcaster@electrotech.ws
718-626-7700 ext 120
Message 10 of 10
DarrenP
for vault 2015 no
only office 2010 & 2013
Vault 2014 was the last to support Office 2007
DarrenP
