Hi
My inventor 2012 does not appears the "Vault" tab. Well, Even in control panel - Programs and resourses - Autodesk vault Client (Add features) does not show me the box to install the inventor add in (See the attachment).
Should I look for another installer???
Solved by DarrenP. Go to Solution.
you use the vault 2012 add in to connect to a 2013 adms console no need to install anything else
http://crackingthevault.typepad.com/crackingthevault/2012/04/vault-2013-forward-compatibility.html
DarrenP
Sorry.
My post goes with an error...
I use autodesk vault client 2013! with a version 2012 of Inventor!.
In my case, the tab "vault" does not appears in Inventor 2012 (see the attachment).
Do you know something?
read the above link
you use the vault 2012 add in to log on to a 2013 adms console
DarrenP
you need to put the 2012 client back on
DarrenP
