Hi.
Trying to test Vault 2014 environment after recent upgrade.
The setup is like:
ADMS Basic 2014 on a fresh 2008r2-SP1 box.
Test client on a W7-machine.
Both the server and the client has Vault 2014 SP1 and hotfix 2 installed.
The Vault is running as a Content Center only, with single user project files, and the environment uses ProductstreamProfessional to manage the file store.
Here´s the problem.
When I try login to Vault client as "Content Center read only User", i get the error "Object not set to an instance of an object"
When I login as administrator, everything works fine, and I can place parts from Content Center.
I tried to rename the folder C:\users\<user>\appdata\autodesk. When starting Inventor the folder reappears with new files, but the error still remains.
What else can I do?
Solved by gunnar_larsson. Go to Solution.
Hi Gunnar,
This is a known issue. Please create a Vault user, CCUSER for example. Give it content center editor rights, and assign the user to the out of the box vault as a Vault Consumer (so they aren't tempted to check things into the vault database) and have them login using this one user account.
That´s what I did, but the common user should not have CC editor rights in this case
The company has a standards department which takes care of all CC updates.
Thank You for answering.
