When utilizng a sheet set that resides in Vault 2014 Professional through AutoCAD 2014, when we right click on the sheet list subroup create a sheet and check it in the sheet set is not updating? The file is checked into the Vault but does not show up in the list. Please help!!! Has anyone else seen this issue?
Solved by jeffwebb78. Go to Solution.
The error was happening on existing sheet sets that were created under Vault 2013 and migrated over to the new release 2014. When we create a blank new sheet set under Vault 2014 the issue goes away. Solution is to delete your old sheet set and re-create under the new platform.
