is there a way how to reset Admin password? We lost it. Probably somewhere through SQL in Management Studio? Cany anyone help us with that? We quiet hurry on that 😞
Thank you
Solved by minkd. Go to Solution.
Are you running a Vault backup in task scheduler? If so, look at the .bat file and it sould have a User and Password that has administrative access.
If you have another user with administration rights you can perhaps login to the adms as this user.
than you can modify the user administrator and delete the passwort and set a new one
changing the passwort over the sql managemant is possible but you must have a default value
