Vault General
Distinguished Contributor
Infoseeker
Message 1 of 3 (247 Views)
Vault 2013 new folder display. How to go back to the old way?!?
247 Views, 2 Replies
02-13-2013 03:39 PM
Before, when you clicked on a folder, Vault would show contents of a folder only but not the other folders in it. 2013 shows first the list of folders (which I can see anyways when I expand plus by the folder on the right side of the interface) then the contents - I need to scroll down to see the files in this particular folder. This is confusing.
Geez, some changes are good, some changes are just to pretend its a new and better version... This is the second. At least thats the way I see it.
Is there a way to change it back to the way previous display?
Employee
olearya
Message 2 of 3 (227 Views)
Re: Vault 2013 new folder display. How to go back to the old way?!?
02-14-2013 04:46 PM in reply to: Infoseeker
Hey there,
2013 introduced a number of folder improvements, including search for folders, folder based categories, properties, project dashboards (reports on folders).  The appearance of folders in the main pane was a requirement for some of these changes.
If you want to remove folders I would look at setting up a custom view with a filter.  Something like "Category Name does not contain folder".
As long as you use the word "folder" somewhere in your folder category names (like the default folder category) this would remove them.
Hope this helps
Allan
Product Manager
Autodesk, Inc.
*Expert Elite*
cbenner
Message 3 of 3 (216 Views)
02-15-2013 05:00 AM in reply to: olearya
I don't mind seeing the folders, it has actually saved me some time once in a while.. But, that said, I just tested your filter and it worked great.  The folders were removed from the view window.  Well played, sir.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
