Could someone help me find the setting to disable Vault 2013 Log-In from remembering my password? I never set anything to remember my passwords, because that seems (to me, anyway) to defeat the purpose! Anyone else think this way?
Solved by r.smith1. Go to Solution.
Solved by mollons. Go to Solution.
Are you referring to the 'Automatically log in next session' option? If so, choose Log Out. That will allow you to choose log in and will present you with the log in dialog and will not sign in automatically. If this is not what you're looking for, let me know.
Adam
Nope! I do not have that little box checked. When I go to log in, the password field has a bunch of dots in it and if I just hit the OK button, I log in successfully. Here is a snapshot, which I should have included originally.
And to be even more clear, I have tried clearing the Password frame, clicked OK, and was (naturally) denied access. I then cancelled the log-in attempt. When I subsequently tried logging in again, the dots (and thus the password) were still there.
Got it. Top priority hotfix in the works. Please stay tuned.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19837065&linkID=9261341
DL19837065 Vault 2013 Hotfix – Vault Login Issue
New Updates
