I created a scheduled backup in ADMS Console 2013 (Vault Basic version). Is there a way to edit this scheduled backup using the ADMS Console?
Solved by olearya. Go to Solution.
Hi there,
The console tool is used primarily to create the backup, once the scheduled task is setup you should be modifying this through scheduled tasks interface. You could of course delete the existing task and rebuild from the Console but this does not make too much sense.
