Vault General
Member
ericdizon
Message 1 of 7 (280 Views)
Vault 2013 Collaboration Replicated Environment
280 Views, 6 Replies
03-05-2013 07:37 AM
We are using Vault Collaboration 2013 with the following setup
      Canada - Publisher            - Domain1
      China    - Subscriber          - Domain2
I promoted all the users to domain accounts under Canada ADMS server for both domains.  All users from Domain1 can login properly no issue.  But users from Domain2 are getting "The user name and\or passsword appears to be invalid, please try again.  In short they are not being authenticated properly.  I rebuild the index after I promoted users.
For the ADMS Vault Impersonation account the Canada Server uses a Domain1 user account.  But for the China server it only uses a Local PC Account.  Would I be right if this is the one causing the issue?  If I need to change theVault Impersonation account for China Server what would it affect?  My worry is if I change it would affect the replication setup we have right now that is working properly....
Board Manager
ihayesjr
Message 2 of 7 (267 Views)
Re: Vault 2013 Collaboration Replicated Environment
03-05-2013 09:02 AM in reply to: ericdizon
The impersonation account has nothing to do with user authentication.  Your users in China are authentication through their workstion to the Active Directories in China.  Therefore you will need a Trust relationship between the Canada and China domains.
Irvin Hayes Jr
Product Manager
Autodesk, Inc.
Member
ericdizon
Message 3 of 7 (260 Views)
03-05-2013 11:07 AM in reply to: ericdizon
Yes, there is a trust relationship between our domains, because both domains are child domains of the same root / forest.. There is not much settings to play around ADMS to see why is not working...
Board Manager
ihayesjr
Message 4 of 7 (257 Views)
03-05-2013 11:12 AM in reply to: ericdizon
Can you take a look in the ADMS Console's Vlogs to see what error is being returned?  Also, look in the server's Event Viewer log to see if there are also authentication issues.  It might be in the Security log or System log.
If nothing appears in either, try turning on Auditing on the server, then authentication errors should appear in the Security log.
Irvin Hayes Jr
Product Manager
Autodesk, Inc.
Member
ericdizon
Message 5 of 7 (230 Views)
03-07-2013 07:59 AM in reply to: ihayesjr
Hi these are the logs that I got from the server both Vlogs and IIS logs.  I don't see any obvious error in the Event viewer under Security or System.  The errors that I see on the Vlogs are Exception: InvalidUserPassword [301]
or Exception: WinAuthUserNotFound [312] when my China users logs in.  Hope this helps and thank you for your assistance.
Member
ericdizon
Message 6 of 7 (229 Views)
03-07-2013 07:59 AM in reply to: ericdizon
Distinguished Contributor
c.dewhurst
Message 7 of 7 (112 Views)
09-10-2013 08:25 AM in reply to: ericdizon
Any resolution to this? I'm getting same WinAuthUserNotFound [312] when using hostname for server, using IP will log in. DNS is fine, I can ping, resolve etc. Server is in same local domain. Stupid thing is I can login to the replicated servers which are on trusted domains just fine.
You are not logged in.
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
