We are using Vault Collaboration 2013 with the following setup
Canada - Publisher - Domain1
China - Subscriber - Domain2
I promoted all the users to domain accounts under Canada ADMS server for both domains. All users from Domain1 can login properly no issue. But users from Domain2 are getting "The user name and\or passsword appears to be invalid, please try again. In short they are not being authenticated properly. I rebuild the index after I promoted users.
For the ADMS Vault Impersonation account the Canada Server uses a Domain1 user account. But for the China server it only uses a Local PC Account. Would I be right if this is the one causing the issue? If I need to change theVault Impersonation account for China Server what would it affect? My worry is if I change it would affect the replication setup we have right now that is working properly....
The impersonation account has nothing to do with user authentication. Your users in China are authentication through their workstion to the Active Directories in China. Therefore you will need a Trust relationship between the Canada and China domains.
Yes, there is a trust relationship between our domains, because both domains are child domains of the same root / forest.. There is not much settings to play around ADMS to see why is not working...
Can you take a look in the ADMS Console's Vlogs to see what error is being returned? Also, look in the server's Event Viewer log to see if there are also authentication issues. It might be in the Security log or System log.
If nothing appears in either, try turning on Auditing on the server, then authentication errors should appear in the Security log.
Hi these are the logs that I got from the server both Vlogs and IIS logs. I don't see any obvious error in the Event viewer under Security or System. The errors that I see on the Vlogs are Exception: InvalidUserPassword [301]
or Exception: WinAuthUserNotFound [312] when my China users logs in. Hope this helps and thank you for your assistance.
